Wishes
Label Parameter
It would be very helpful to have the Label tool to extract and show ANY of the parameters of ANY object.
For instance, i would like to create labels showing only the Electrical data from the equipment inserted.
Any of the "Parameters for Listing" should be able to get on a label to show on plans, like the Surface and ID label do
1 REPLY 1
This is possible to do with IFC Properties. You can map an IFC Property to any parameter of any element and then you can display that IFC Property with the "Tags and Categories" Label.
Check out the below steps, you would have to do something similar:
http://archicad-talk.graphisoft.com/viewtopic.php?p=233623#233623
Learn and get certified!
