Wishes forum
Larger Object Interface
JGoode
It's quite limiting having the object user interface the size it is. Of course you can just move onto another page but it would make it so much easier and user friendly to be able to include more on a single interface page. You can adjust the size of MVO pages so I can't see why it wouldn't be possible for Graphisoft to implement it for object interfaces.
ArchiCAD 17, 19, 21 and 23
Windows 8
Podolsky
Ace
It's actually already there. Just set bigger size in command
UI_DIALOG title [, size_x, size_y]
GDL user manual saying that size_x and size_y are not used, but this is not true - it's working.
JGoode
I just had a look at this. It kind of works however you are able to shrink the Object Default Settings window to cut out anything that is outside of the standard x and y
Windows 8
