2004-10-26 04:21 PM
2004-10-26 10:53 PM
2004-10-27 03:09 AM
2004-10-27 03:42 AM
James wrote:That would be a great improvement. I could see setting up different view sets that would allow construction notes to be printed for check sets and off for final drawings.
I did forget to add more more feature to my list (will have to update that tonight).
I would like to see an additional setting for each layer of Print/No Print. So inotherwords a layer can be visable but won't print. This would be useful for construction layers. This might be indicated with a print icon and a printer with a cross through it.
Would others find this useful as well?
2004-10-27 03:43 PM
oreopoulos wrote:Thanks for the suggestions. See the image above again as I've now implemented your suggestion 1.
May i add some more features.
1. When selecting a combo have a button to show all or only the "on" layers.
Its a feature to check what the combo includes, especially when the list of layers is getting too long.
2. The second feature was suggested in another wish thread, and its about better layer manipulation (with combos in mind)
When i have to add a few layes in an already big list of both layes and combos i just wish someone else did that job
2004-10-27 05:23 PM
- Ability to swap shown/hidden layers (allow same for lock/unlock)I sure you are already aware of the "quick layers" palette? I would like the quick layers pallette to remember its status so if you quit archicad and restart it will remember if it was shown or not. In addition I would like an unlock option in the "all layers" section (switches to other layers when an item is selected. I'm not sure if these items warrant their own wish but those items would greatly improve its function. It seems like an easy step to have the same features in the layer dialog box.
2004-10-27 09:03 PM
Allow the Layers dialog to be a floating window, allowing for instant results of layer changes (like hiding a layer) - maybeDefinitely. Make it like the Navigator with the push-pin button. In one state OK closes the palette, in the other it doesn’t. Or just add an Apply button like the Attribute Manager.
2004-10-28 12:21 AM
Mike wrote:Yeah, it was the reason I added it into the actual layers settings cause it's pretty useful.- Ability to swap shown/hidden layers (allow same for lock/unlock)I sure you are already aware of the "quick layers" palette?
2004-10-28 08:38 PM
2004-11-08 01:51 PM
