Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Layer Settings Improvements
James B
OK, I've played around with the layer settings dialogue.
Things I'd like to see (from my website):
- Ability to group layers in folders (allow for draging of layers), the folder may have hide/show and lock/unlock global settings for it's contained layers.
- Allow the Layers dialog to be a floating window, allowing for instant results of layer changes (like hiding a layer) - maybe
- More streamlined interface - too many large buttons
- Double click a name to rename a layer or layer combination
- Ability to swap shown/hidden layers (allow same for lock/unlock)
- New Column added next to "Extension" to indicate layer(s) a selected object or ojects are on (maybe have the ability to drag this selected object icon to another layer to move object to that layer). The icon could indicate what object is selected on that layer (ie wall, slab, column etc or multiple objects).
What do other people think?
EDIT: Image updated to include new printable/non-printable setting and oreopoulos suggestions. thanks for that (to only display visable layers option to simplify layers list when a combo is selected).
James Badcock
Graphisoft Senior Product Manager
19 REPLIES 19
James,
I think that your idea of having layers grouped together in folders the way you show would be a grand idea. As it is now we use a design pln file that only has the layers that are needed for the design phase. When finished with the design it is merged into a pln file with total layers needed for construction documentation. If it were the way that you have shown we could group and simplify as needed layers into catagories such as design and CD's. This would keep it simple for the initial work and expand as the design developes into the later stages.
James B
I think having a folder system integrated into Layers will help with xrefs/dwg imports, hotlinked modules and when doing multiple options mostly.
i have when I do the above and you end up with a hundred new layers, then you need to go to attributes manager to purge empty layers etc. Becomes a nightmare to manage.
Now that's it's added to the wishlist, lets see what GS does.
James Badcock
MSotero
Balazs wrote:
Hi James!
Already added to wishlist.
Working has been started in this theme too
Balazs
In that case, you may wish to review this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=6154&highlight=#6154
I think it's time to start a collection to send James to Budapest to work with the Graphisoft developers on their interface for Archicad. All of James' suggestions seem to be well thought out and a great improvement over the existing.
James B
Hey, bring it on I say
I have alot of fun doing it, so I'd be happy to hear more feedback.
James Badcock
James B
I didn't see that thread before. Thanks for the link. Also glad to see we're thinking along the same lines especially re the print/non-print option for layers.
James Badcock
MSotero
To add to your feature list, wouldn't it be nice if we had:
1) A filter button or something to Show Only Layers that are Empty/Not Empty/Both.
2) A column in the Layers side of the dialog that showed the Number of Entities on each layer. This could make it easier to delete unused layers or quickly see if a particular layer has limited/heavy amounts of data on it.
If you like the above ideas and wish to update your image....
Maybe you'd also consider putting a Pen Selector icon in the Layer Combination side of the dialog box promoting the idea of having Multiple Pen Sets (per the link I provided earlier). This icon being in line with the layer combination Name in the scroll list.
James B
I've often thought about how to indicated what elements are on what layers, and what stories the layer has elements on. This I think gets confusing and complicated.
Just adding the "print/non-print" and selected element column adds a level of complexity that is didn't have before. Adding more columns just confuses things I think.
The column on the far right, I was intending to be to describe the layers selected elements are on, and with the ability to drag those items to other layers. Though this could become the column to describe the number of elements on the layers (but a breakdown of what elements are on what layers and story would be a nice to have).
Not sure if I understand the whole Pen thing. So a pen can be global on everything on that layer? Not sure if I understand correctly that one.
Lastly, re purging empty layers from the layers dialogue, well seeing as you can already do this via the Attribute Manager, not sure if it's needed in the Layer Settings - I only tend to have the need to use it every once in a while. I wouldn't want to see the Layer Setting become even more cluttered.
James Badcock
MSotero
James wrote:
This I think gets confusing and complicated...I wouldn't want to see the Layer Setting become even more cluttered.
I'm all for keeping things simple. Isn't it so true that things can become complicated quickly. The art of introducing the right things in the right places is truly a challenge. I certainly experienced that when creating MSA Detailer.
It is also true that at times things can become frustrating for users when forced to use a multistep process which can overly limit possibilities at times. Eventually, these things work their way out but it often takes years.
I've seen a lot of changes since V3.43 when I started using ArchiCAD. Today many of the things people find most appealing about AC were once thought to be overly complicating matters.
You'll might find this amusing. Those of us who remember AC3 might recall that the Layer setting was once a 4x4 grid of buttons giving you 16 Layers. You clicked on each layer button that you'd like an element to be on. While I was explaining to a programmer a layer dialog similar to what we have today, I can still remember him saying things like it was too complicated and who could ever need more that 16 layers anyway. Seems kind of funny from today's perspective.
Anyway, I appreciate yours and so many others contributions even when we don't necessarily agree on specifics at times. I've certainly learned a lot by considering what others have suggested. Often I appreciate alternative working methods that just make things quicker and more flexible.
MSotero
James wrote:
Lastly, re purging empty layers from the layers dialogue, well seeing as you can already do this via the Attribute Manager...
Filtering was the idea, not purging. What Attribute Manager does is limited and doesn't filter layers. If one purges, they might remove layers they were intending to use later and mess up useful layer combinations.
