Lingwisyer wrote:
Have you tried with the new Opening Tool as apposed to using a SEO?
Had a play under AC23 (though AC23 is forbidden until at least first patch - I am stuck with AC22 for production)
However I see that only rectangular or circular holes are available in AC23. The slab rebates I regularly need run right around the perimeter of the slab - and it appears that you cannot even merge adjacent slab holes in plan (a line and shadows remain between them) to form more complex shapes. Nor can you change hole edge angles or add or move individual nodes to hole definition to make more complex shapes.
And even if I could live with that, level dimensions still suffer from the same dumb behaviour - ignoring the modifications to surface height as before - whether made by hole tool or old school SEO.
In this case, even if a hole is only partial depth of slab, the level tool thinks it goes all the way through.
Unless I am missing something (?) this all seems disappointingly limited actually.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
