2003-10-30 05:19 PM
2003-10-30 07:35 PM
MMontgomery wrote:As the name says, they are LINE extras - and lines can be seen only in the 2D windows. So ...
How about having the Line Extra tools (intersect, fillet, chamfer) made available for use in the 3D window.
I find myself reaching for those tools when I'm cleaning up walls in the 3D window.Yes, the same (fillet/chamfer/etc) should work for the walls anywhere; CTRL click works for Intersect. However, if my plan is already dimensioned (and I tend to do that heavily) I tend to use Adjust - the end nodes do not get cut and the dimensions do not disappear.
2003-10-30 08:07 PM
2003-10-30 08:35 PM
MMontgomery wrote:Only for Adjust; then you have to draw the direction (lock a coordinate as appropriate or define a parallel direction). AFAIK CTRL Click works in all cases.
I may be doing something wrong, but in order for CTRL click and Adjust to work, doesn't the plane of at least one wall need to be crossing the plane of the other
this might also be fixed if we could select something in the 3D window and switch to plan view and have the same elements selected thereOr, from any window to 3D window; and what is selected in 3D window to be selected in any 2D window.
2003-10-30 08:59 PM
Workaround: Open Find&select, use eyedropper to pick up the unique properties of something from the 3D window, open the 2D window you want, select.Yep. that's how I currently select things from window to window, I ❤️ the Find&Select tool !!
2003-11-27 10:39 AM
