2006-06-23 07:13 PM
2006-06-23 10:25 PM
2006-06-23 10:38 PM
2006-06-23 11:02 PM
2006-06-26 01:44 AM
2006-06-27 01:37 AM
If the detail marker could like to a drawing title object, then I could have several detail drawings together, each with a drawing title object, and the marker would get its info from 1) the drawing number assigned in the drawing title object and 2) from the location of the details in the layout book!This is doable as James said, even though it is a workaround. If you want the detail numbering to be automatic you could select all the multiple instances of that one drawing and assign the Drawing ID to By Layout or even Custom. Then you could title each detail, using the Set As Autotext Reference: Drawing ID ref.
2006-06-30 04:58 AM
2006-06-30 12:55 PM
s2art wrote:Update of internal details in 10 is extremely fast, since they're internal and 2D. I would think multiple instances of one view would be practically instantaneous. I bet you'll be able to move to automatic referencing in 10. I haven't gotten a 10 project to the heavy detailing stage yet, I'll keep watching it.
It also means that PM only has to update the one view, rather than a separate one for each placed detail (yes, still talking AC9, so maybe 10 is better here).
sheet load
2006-07-02 11:58 PM
James wrote:
sheet load
2006-07-03 12:51 AM
James wrote:Yes, poor excuse really.
