Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Marked Distance Areas to Internal Elevations
Liamthanks
I tried searching the forum and couldn't find see this wish already being requested.
How is this not a thing yet? Being able to fade out portions of a room that are not directly relevant to the view but are good for context seems like such a basic function that should be included, considering it is already in the section tool? Currently using a 75% fill over the areas as a work-around at the moment but a pain as it needs to be manually modified if anything changes.
What is everyone else's thoughts?
AC24 Build 7000 AUS - Windows 10 Pro, Ryzen 7 5800X, Radeon 5700 XT, M.2 NVME 0.5TB SSD, 32GB RAM
When the internal elevation became a tool many versions ago, there were bugs with them, so I kept on using sections.
I'm still using sections now.
They work as you would expect - the only down side is they are not grouped like the internal elevations can be.
Liamthanks
Yeah a lot of builders I have worked for have done the same thing so I've had exposure to both, but personally like the internal elevations tool.
