2008-11-13 02:05 PM
2021-05-10 09:15 PM
2021-05-10 11:49 PM
2021-05-11 01:10 AM
2021-05-11 05:24 AM
Podolsky wrote:It's good enough for me - thanks for pointing this out, as I haven't used multistory hotlinks in quite a while!
Sorry, I didn't get it. There was update for hotlinks several years ago, is it not the same? I can place my multi-storey hotlink that can follow storey heights and elevations, as it set inside of holinked file and not as in master. What else is needed?
2021-05-11 06:20 AM
Karl wrote:
will you get a warning for the missing stories or will the content just not appear in the project?
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-05-11 11:17 AM
2021-05-11 12:29 PM
2021-05-11 02:09 PM
2021-05-11 08:25 PM
Lingwisyer wrote:Thanks, Ling! That makes this good anough for my personal uses, as I only ever needed a 3D campus model... and a top-down site plan. But, I see the issues that Aaron and Braza bring up concerning the FPCP view.
You get a warning when you add the module and a note next to the module in the manager. You then need to manually add the required extra stories for the relevant content to be visible, so in the end your master file will match the story count of your largest modules.
