Wishes forum
Mental Calculation Slow Downs
Fellow AC users before I make a request, I would like to ask how do you minimise the number of mental calculations when moving elements into position without an interactive temporary pop up dimension marker showing up when you click an element?
In simple terms most CAD programs have this method but we don't have it yet or will probably never get it either?
for example I have a room dividing wall with an AC interactive dimension showing 2735 and I want to move it to lets say 3020, In my head I go 3020 minus 2735 is 285 after my brain ticks over I drag the wall 285mm into place. There must be a better way to do this as it wastes allot of time for me when you can just click a temporary dimension and feed the 3020 value in???
What do you do?
36 REPLIES 36
laszlonagy wrote:
You original issue was not solved by this. The tips others have provided in this thread are the way to go when modifying element locations relative to a given point.
However, when placing certain elements (e.g Doors/Windows in Walls), there is something new.
In ARCHICAD 19 it will be possible to place a Snap Reference at the corner of a Wall. Then when you place your cursor along the edge of the Wall, the Tracker will display the distance from the Snap Reference. You can then simply type the value you want the element to be placed from the Snap Reference along the edge and press ENTER, done.
So, to place a Window 1000 millimeters from a Wall corner:
1. Hover the cursor over the corner, press Q, the corner is immediately marked as Snap Reference.
2. Hover your cursor along the Wall edge, type "1000", then ENTER on your keyboard (no TAB needed to enter the Tracker, no repositioning of the User Origin is needed).
3. Click to define Window direction.
No, my original problem was with elements as a whole and walls were used as an example.
Are you saying that this technique will not work with walls?
What about the blue reference line along a wall?
One video explained what these reference guides will not work with and walls were not among them. Am I mistaken?
Your original question, if I am not mistaken, was about moving elements.
When you move elements distances in the Tracker are measured from the Edit Origin, which is at the point from which you drag when you move the element. This is the case in ARCHICAD 19 as well, even if you have marked Snap References. So you would have to reposition the Edit Origin with ALT+SHIFT to the point from which you wish to measure the distance and then enter the new distance in the Tracker. This is why I said that you would have to do the same others suggested in AC19 as well.
Of course any construction type element node or edge can be marked as a Snap Reference. Only 2D Annotation type element (Markers, Dimensions, Texts, Labels) nodes and edges cannot be.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
As Laszlo says this doesn't work when you are moving an existing element (even doors and windows) - you still have to reset the origin if you don't want it based on the original drag from point.
But it does work when placing any NEW element - windows, doors, walls, slabs, etc.
Versions 6.5 to 25
Barry I think I saw that at the end of the last video in that section?
How does this new system of reference point now differ from placing a user point of origin when moving an existing element?
It doesn't.
To move an existing element you either use the initial drag origin or set a new one with the ALT+SHIFT shortcut.
It is exactly the same as it was before unless I am misunderstanding what you want.
The new snap reference just means you do not have to set the origin when placing new elements.
Versions 6.5 to 25
Barry wrote:
It doe n't.
The new snap reference just means you do not have to set tmhe origin when placing new elements.
The video man grabs the window and door together and chooses drag then takes his cursor to the reference point and it shows it is 1750 away from the corner and then enters 600 from what I can tell it is job done edit completed?
You still have to click the corner to set it as a reference point as I understand in the reference mode. And that point or any other points or guide lines you create stay active till you delete them? So regardless if it is a new element or you are editing and existing element it should still work right?
I think there are less steps now involved with this new method of placing and editing existing elements as I see it. I will give it a test run when I get my upgrade.
Which video were you watching - maybe I should watch it too.
Can you post a link please?
Versions 6.5 to 25
It is this video:
https://www.youtube.com/watch?v=UaxOUutgn0g
from about 1:05
This clip is not about numeric input. It demonstrates only that when you have a Snap Reference it will disappear after the element editing step is finished.
However, to your specific question: in the clip, at 1:12 the Wall Corner is marker as Snap Reference. Then at 1:15 "600" is typed in the Tracker. But also at 1:16 you can see for a moment that the value in the Tracker changes to "1150". This is because the "-" (minus) character was then typed. So the mouse was hovered at the corner, Tracker displays "1750". Then "600" is typed, Tracker displays "600". Then "-" character is pressed, 600 is deducted from 1750, Tracker displays "1150".
So it is not measured from the Snap Reference point (in that case it would display "600", but not "1150" after that). It works the same way as in previous versions.
You are right is suggesting that this may be confusing because the fact the the Snap reference is created just before typing the value and measuring relative to the corner that was just marked as Snap Reference, can give this impression.
So I will suggest this clip to be revised to make it less ambiguous.
OK I will wait till I get AC 19 before I get too specific about this supposed speed up?
I believe this should be even faster in AC 20, how?
1) set your reference points and dotted lines.
2) be able to get a reading in the tracker called DNPR "Distance to Nearest Point of Reference" for example a corner.
3) Left Click the element to select it, the tracker comes up with DPNR enter your new value and you are done.
Note this will work with placement of new elements as well as editing existing.
Laszlo its more important to ask Graphisoft to consider this so we can be as fast as Revit once and for all on speed issues in all areas of the program including element creation and editing.
I was thinking about this a bit more and I realized that you could do it even current ARCHICAD versions.
You have to switch off the Relative Coordinates in Tracker toggle (so the Tracker will display absolute coordinates - absolute coordinates are measured from the User Origin).
Then place the User Origin at the Wall Corner. Then start dragging the Door/Window in the Wall and simply type "600 ENTER" if you want it 600 from the Wall Corner.
But this whole thing is still slower than simply hovering the cursor on the Wall Corner and typing "600- ENTER".
Thanks, I have used the UPO in the corner then left click drag with the PP set to drag then drag the opening to the corner at the UPO then enter the value I want.
So I can set the TP from relative to absolute before dragging an element?
Thanks, I will test this out and if I have any problems I will let you know.
In that Video, I am sure that 600 was entered into the TP then -1150 showed up in the TP since the corner of the window was at -1750 then entering +600 = -1150 to where the window and door were dragged.
"1750", "600-" and "1150", respectively.
Thanks for the Tip on setting the TP to absolute with the UO in the corner, that works.
I still have to set a UO at every point or corner while editing elements in AC18.
Why can't we have the TP set to a mode when creating or editing elements that will allow us to automatically have "Reference Points" like wall corners or opening corners or even element center points that show up with distances to them? Then we add a positve value or distance from one of those points like the nearest corner of an existing element for placing and editing elements.
I think a method like this would be faster than Revit, Chief Architect, SketchUp and other CAD software because it gives us an easy way for the first and accurate placement of elements along with the other tools we have. Lots of these CAD softwares allow for random placement of elements and then they are accurately placed after the temp reference dimension from nearest corner comes up.
If our TP could do this it could gives us a few options on where to place or move an existing element along a wall that is parallel with an element like an opening. For example distance to closest corner in the x direction and distance to closest corner in the -x direction and same for the y and z axis.
OK, I think we have discussed this topic at great length so everyone reading this will have enough information to decide whether to support this wish or not.
In AC 19, can I get absolute values or distances in the TP to reference points and lines right now or only with the UO?
This problem is close to being solved right now in AC 19 or if in your opinion it is not then at least the scaffolding is in place for further tweaking in the software language.
The next step to speeding up, is doing the job faster again with touch screen inputs.
No, distances are always measured as absolute distances (relative to the User Origin) or relative distances (relative to the Edit Origin). They cannot be set to be measured relative to Snap Reference Points (unless you place the User Origin to a point marked as Snap Reference).
OK I still have to do mental calculations in AC19 I will get over it
