Wishes forum
Minimal Space for Objects in v25
Steve Jepson
Minimal Space feature should have an on or  off  Toggle.  As it is now, you have to set each dimension to 0 in order to shut it off - doing it that way means you have to type in the dimensions again when you want to see it.  The other way to turn it off or on is with Model View Options,  but that turns all minimal space displays either on or off.  It would just be easier if we could also toggle it on or of in the object menu.
ArchiCAD 25 6000 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
1 REPLY 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Steve,
Thank you very much for sharing this great idea!
I am happy to say we took notice of this wish and I have added it to our Wish List database (please refer to it as IDEA-4397). Hopefully, our Product Management team will adopt this one in the future.
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
