Every object that uses MVO settings should have the option to use the MVO settings or not.
This way it can be excluded from the MVO.
Then if the MVO feature is turned off you should still be able to manually turn on/off that setting in the object.
If the objects are not scripted this way then they should be (in my opinion).
