If you used "Place External Drawing" to place the file then you can explode it and mirror it.
Placing as a drawing is just like the drawing on the layout pages - they can't be mirrored either.
Or you can just 'Merge' the DWG into your model - then you can mirror straight away.
If you placed the DWG as an XREF, I don't think you can do much with that.
I have never had to deal with XREFs so I am not sure on this one.
