Wishes forum
Model Filter View Option
Braza
Edit: I have made a considerable modification to this whish, which is described here.
Hi There,
Now that AC23 is announced, I'd like to make ARCHICAD Design team´s life easy for the next year and wish just One feature for AC24.
I would call it "Property Filter View Option".
I'm sure this wish alone could fulfill lots of standing wishes of us ARCHICAD users.
I think it is quite easy to implement, as it could use existing routines in the Schedule Scheme Settings Dialogs.
Basically, you could filter your views to only show elements with a defined logical criteria. Which IMO is way better than handle it with layers and layer combinations.
Some View Options would become obsolete.
Think about Project Phases, Renovation, Drastically Reduce the number of Layers, etc.
Paulo
Paulo Henrique Santos, Architect
AC24_INT#3008 / I7 / 16Gb / 512Mb SSD / Windows 10
18 REPLIES 18
Are you coming from Revit?
This feature request sound to me like View Filters in Revit.
Anyway, I think such a functionality was discussed before, and the easiest solution would be to enable Graphic Overrides to hide elements meeting a specified Override Criteria. Such a functionality would be welcome by me.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Braza
Hi Laszlo,
No I'm not coming from Revit. My brain is too old for this...
Since Graphisoft start developing its "properties/calculation features", it Just seems to me the logical and simple way to deal with some long standing wishes using already existent resources.
Of course I'm not expecting it for AC24...
Let's see if Nemetchek will stop for a while dragging down ARCHICAD core development by attaching it to other product families... I know it is a good business move, but it still a pain in the arse for us.
But anyway... I think that this feature alone could be a game change for Graphisoft.
Paulo
Braza
Another wish that could be addressed with "Property Filter View Option"...
https://archicad-talk.graphisoft.com/viewtopic.php?f=28&t=66971
Braza
and another one: https://archicad-talk.graphisoft.com/viewtopic.php?f=24&t=63348
DGSketcher
Mentor
I'm sitting on the fence with this. As much as I can see the 3D filters being useful alternative to modelling with layers, we are still left with the documentation issue which only really works with layers. IIRC AC was originally split between modelling & publishing and Sketchup has gone through the same process that ends up with an amalgamation of 3D modelling views which are then passed to a 2D environment with layers for documentation. If you are looking to remove layers from the documentation process I don't think it would work. It could even complicate the situation as in Navigator you would need a 3D Model View Map as well as a 2D View Map for annotation before passing the 2D results to Layouts. How do you see your wish operating with the documenting process?
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
Braza
Property Filter View Option could work on both 2d and 3d.
Most of Archicad elements (for documenting and modeling) can have properties assigned. If I remember well only Figure, Drawing, Section, Detail, Worksheet and Camera Tools can't have properties assigned.
I can't see any technical/programming issue in adding property capabilities to these tools. Please correct me if I am wrong.
Documenting elements could be filtered, as per view, the same way as modeling elements.
I can't see any problem/conflict in Navigator, as each View and Project Map could have their own "Property Filter". Could you describe a working situation?
Braza
And by the way...
Property Filters could be applied to Complex Profiles, by assigning properties to Building Material fills.
DGSketcher
Mentor
Details & Worksheets create independent 2D data and as a consequence loose significant associations with the model data e.g. a wall will become a brick material fill. Do you then have to create new data to manage the 2D view? If the fills inherit the original properties / categories of the wall then that would be helpful.
You are asking a lot of GS and such matters need to evolve to work with legacy data which may be 10 or more years old. Those old elements won't have property data and therefore will need the layer system if AC is to display the information correctly on opening without someone spending days or even weeks updating each element.
As a first step you need to persuade GS of the benefits of a Property Filter and add it to either the Model Display option or as Laszlo suggested Graphic Overrides, although I think the latter can already be a challenging management exercise without adding property filters. Filtering the model by properties / categories in plan, section & elevation has much appeal but equally you may find the filtering process to be no less complicated than layers given the number of possible categories & properties that could be used to describe a single element. Have you considered data reliability in your assessment e.g. how easy is it to find an object that is misdescribed and therefore fails the filter display criteria? Would you even realise a critical beam was missing because a property value was not set?
Braza
Sure 2d elements should inherit original properties.
For legacy matters, all elements (2d or 3d) should have at least one Property that can be called "Layer" in wich there is an "Archicad Layer" by default that can't be deleted, but you can add more itens in a dropdown list checkbox. Old project can be acessed by converting "Layer" to "Property Layer".
The current layer system, is a binary one. You have to choose what you want to see, and what you don't want to see for each Project and View Map. The logic of a Property Filtering system is much more advanced than this. For a simple example: I can create a Property called "View Maps Property", that could list all the available View Maps on the project with a dropdown checklist in wich I could check all the View Maps I'd like that element to be seen.
Then I'd create a Property Filter for each View Map that would Select All Elements that its "View Maps Property" contains "Current View Map". The power of a Property Filtering system is endless and can suit all the user possible needs.
IMHO Graphic Overrides must be kept doing what it does best. Wich is: Graphic Overrides. Not visibility control. Adding a visibility control to GO would add another level of mess that Renovation and Parcial Structure Views already are.
We already have misdescribed elements in the current Layer system. Misdescribed elements are just matter of Project hygiene.
But anyway... I am not trying to persuade GS... It is just a sugestion.
DGSketcher
Mentor
There is another option which wouldn't take much effort by GS to implement, although it may not meet your filtering expectations and that would be to remove the "Binary" status of the renovation filter and allow for objects to appear in multiple renovation settings. This would simultaneously remove some of the phasing frustration that has been mentioned elsewhere but it would also be adaptable to allow for property filtering. The user can use a saved "Find and Select" for filtering by property and then simply assign the appropriate renovation status for those objects to be displayed. How does that sound?
Braza
It would work. But honestly... It's not what I would expect from a company that is commited to be the number one on the market.
No offence... Your solution is functional but it would always be like a "Silver Tape" on a leaking pipe in a combustion diesel engine.
I think that a Property Filter View Option could be the "Unified Theory" of project documentation.
Braza
Ok. It has passed a year since I have posted this long time whish (Which is also very known in the community), and I would like to present some improvements to the original idea.
Initially, I proposed a Property Filtering System in alternative to the outdated Layer System. And I came to the conclusion, that this Filtering System could be applied not only to properties, but to all Elements within Archicad.
So. Now I propose the creation of what I call "Model Filter View Options" Settings Dialog Box. It would be similar to the Graphic Override Settings Dialog Box, in which we could create Combinations and Rules. The main goal to this approach would be to completely eliminate the existent Layer Settings Dialog Box (Which have the Lock/Unlock, Solid/Wireframe and Intersection Group Number that are still essential for the project workflow), but also allowing to manage legacy issues. I also remember that this solution would demand that each and every 2d/3d element in Archicad could have Properties assigned and a Layer Property would be standard and undeletable to each element. As you can see in the illustration, the Lock/Unlock, Solid/Wireframe and Intersection Group Number would be assigned at a Rule Level in the Filter Combination Dialog Box. This approach would also eliminate the Renovation and Partial Structure Dislplay Pallet, as the Renovation Status and Structure Function would be other standard non delectable property like Layers.
Basically these are the new ideas to this whish IMO, which along with a Dedicated Shared Resource File, is the crucial improvements that Archicad need at the moment.
I will maintain the Poll with the votes as they are, because I think that the essence of the whish is still the same. But I will put a note on the first post linking to this one just for update reasons. (Edit: Well... it seems that if you change the Title of the Poll it automatically reinitiate the vote count. Which is logical. )
All comments are appreciated.
DGSketcher
Mentor
@Paulo, I think you may be hitting the developers brick wall now. I can see how classifications should play an important part in the model display. How that is implemented will come down to GS who I would hope have a better handle on their data structure and roadmap than you or I. It is good to keep the idea alive, but I think we know that you can tell GS something isn't as it should be and if they feel like it they will implement their own solution and ignore consequential user problems anyway.
Braza
Yes. Another tricky whish. It won't be long until GS kick me out of here.
I revisited this whish after this post by Tim Ball. I agree with the idea of assigning data at a Building Material level. And with a Model Filter View Option, it would be the documentation nirvana.
Braza
Just adding, as requested, an UNSELECTABLE LAYER OPTION to my proposed Filter Rule Dialog Box.
jan_filipec
God yes, we need this SO much. What the hell are layers doing in a BIM software in 2020?
We define the building geometry and add data to the geometry and we simply need the resulting drawing to reflect the data we defined - filter what we see according to it's parameters and style it, again according to it's parameters. It's as trivial as that.
vazkez
Thanks Braza for developing and elaborating this wish in details. In my opinion it is crucially important. Limitations of layers and layer sets do not allow to manage and document BIM model in ArchiCAD enough effectively. However I would make this functionality parallel to existing layers system instead of making a replacement. That would leave decision to user which system to use (it is a new level of complication not everyone is willing to accept) and also would make exporting to other formats that use layers system less complicated.
Israel de Quevedo
A basic template could be created with element overrides based on classical layers, and another template for element override using more advanced filters. You just have to choose the template that you like the most.
