2010-02-19 04:16 AM
2010-02-19 03:20 PM
2010-02-22 01:31 AM
2010-03-03 06:19 AM
David wrote:That is why I want something "like" an MVO but not stored as an MVO combination so it will not be stored in the views.
I think I understand your need, but I am not sure that the Model View Options is the best place for entering and storing this information, as the Model View Options are tied to views, are intended to change as the views are changed.
David wrote:Yes but you can't have the nice graphical interface as in the MVO.
It seems like the Project Info window would be closer, as this contains information specific to the project that does not change with the view. Have you looked at using this to input and use this type of information?
2010-03-03 08:04 AM
2010-03-03 08:52 AM
Geoff wrote:As you say the favourites are only good for the next object to be placed or you have to manually select all those you want to alter and then ALL parameters will change - not just the one or two you want.
Doesn’t this fall into the realm of favorites?
Geoff wrote:That's why I would like to see this implemented without having them saved in the MVO combinations.
The problem with the AC13 implementation of the LibraryGlobal, as has been discussed at length, is twofold. First, it contains settings that no one changes by view (e.g. door swing pen), forcing users to edit every one of their MVOs to edit them.
Geoff wrote:This problem is fairly easy to overcome and has been discussed here.
Second it globalizes settings that users want to vary by instance (e.g. swing line shape), robbing them of that ability. The first is merely inconvenient,. The second a loss of function. So as it stands the current feature is a stark example of what not to do.
2010-03-03 01:51 PM
Barry wrote:So maybe the solution is to add another panel to the Project Info window that would be driven by the same code as the LIBRARYGLOBAL commands, universally for the project without any ties to the MVOs.David wrote:Yes but you can't have the nice graphical interface as in the MVO.
2010-03-03 06:09 PM
2010-03-03 11:17 PM
Barry wrote:I did read that and I appreciate your explanation. I plan to use this for some of my objects. But it is not reasonable to expect users to fix the OOTB doors and windows (especially give the frequency of library updates). That is Graphisoft's job.
http://archicad-talk.graphisoft.com/viewtopic.php?t=31036
Each object just needs a parameter switch to allow it to use the LibraryGlobal (or LibraryLocal or whatever it may be called) settings or not.
We can then have global settings that can be over-ridden by individual objects and we can also choose to have the parameters saved with the MVO combinations or just as an overall parameter that can be changed at will but stays constant no matter what MVO is used.I like the sounds of that. Incorporating your notion of using schedules, maybe both the MVO and favorite thingy use a criteria picker, like the IS, to add any combination of existing parameters to the control mechanism. Then GS doesn't have use us as guinea pigs to figure out which ones work and which don't.
2010-03-04 02:58 AM
Erika wrote:I think you would need more than just a text editor to understand and edit a PRF file directly.
Not a solution but perhaps a workaround. Can you put this info in the favorites prf file?
Export the favorites, open the prf file in a text editor, insert your lines of code and then reimport it into the file?
I'm obviously not a GDL expert, but would this work?
