Wishes forum
Mono pitch truss download.
Johann_P
Just wondering if there is a customizable mono pitch truss which shows web-members available for download somewhere.
I only seem to have one without web members.
There seems to be a post from 2014, but the link just takes me to a website.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 ACCEPTED SOLUTION
Solution
4dProof
have you tried the truss maker? design > design extras > truss maker... it's based on pLines... draft out the centerline of the truss members and convert to a truss
Otherwise, you could model the truss with beams, select them in plan view, then go to file > libraries and objects > save selection as > object to save the beams as an object
BIM solutions and trouble shooting (self proclaimed) expert
7 REPLIES 7
Solution
4dProof
Johann_P
Great thanks!
I did not know about "Truss maker"
Windows 10 Pro
Aaron Bourgoin
My one comment would be that the ribs of a truss are the responsibility of the truss designer/engineer/manufacturer. If you are that person, then I can see why you would want to model the ribs. If you are the building designer, then the heel height of the truss and the roof pitch would be the only parameters you would want to input and have control over. The out-of-the-box  truss objects do both I think.
Think Like a Spec Writer
AC4.55 through 26 / USA AC25-5010 USA
Rhino 7 Mac
MacOS 11.6.5
Johann_P
Indeed Aaron, you are correct.
But my goal is to show open trusses without a ceiling in a 3D render in Twinmotion.
Thus the ribs / webs of the truss does not need to be perfectly correct, but need to be shown with sufficient detail and accuracy to be used for presentation renders.
It seems the "Truss Maker" tool works for this purpose.
Windows 10 Pro
RandyC
Cadimage has a wonderful truss that configures to dual pitch and single pitch
It also stretches in many directions with overhang, heel height, pitch etc.
CT full truss & CT half truss
ArchiCAD 4.5 --- 25 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Erwin Edel
This would be something you could make with the param-o tool, if you feel like you need to adjust the dimensions a few times during design.
I ussually estimate how many times I would adjust the element and how long it would take me to do a bit of basic math to plot out the connection points and boundary of the shape. If I feel like I would use the element in multiple projects going forward, it is often worth spending 1-2 hours to make something parametric.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
You can also use the Curtain Wall tool to model the Truss. You can even do it in a Section or Elevation Viewpoint.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
