Wishes
More & better GRAPHIC OVERRIDE options
Leire Bilbao
The graphic overrides are awesome, but many times you need more. For example:
- override a part of a bigger object, but not the whole object (like a window, complex profile, wall, composite, stairs...).
- override surfaces in an elevation
- override the lines of a wall different depending on its surfaces for a wall finishes plan
- many criteria are "contains" and that gives you the wrong override with composites and materials
0 REPLIES 0
Learn and get certified!
