Having two (at least) two depths and the ability to break the line as you suggest would finally put AC on par with or beyond my old 2D elevations.
May I also suggest that when the main (visible) section line is segmented (my preference) that the segments be stretchable instead of numerically controlled. I frequently want one longer than the other to reach past dimensions and the like.
Regards,
Geoff Briggs
DeForest Architects
Seattle, USA
AC25 INT, Mac (home), Win10 (work)
Yes, you read that correctly, we are in the US but use the INT version, because the libraries are better.
