Wishes forum
Moving Levels without moving associated objects
jl_lt
Sometimes you define the levels and while working you decide for better slab positioning. If i want to move my original floor reference level to adjust to the new slabs it creates an asbolute mess. So i would like to have the OPTION to relocate a reference floor level WITHOUT moving its asociated objects. Of course, once the new level is set, the objects become associated with it.
12 REPLIES 12
Brad Elliott
Isn't this the existing Relink Home Story feature?
Mac OS10.13.6 AC23 USA Full
Hackintosh 4 GHz i7 32gb ram NVidia1060
jl_lt
As far as i know, the relink home story works on objects you move around and then you can adjust to which level they belong.
What im talking about is actually the oposite. Im talking about editing the reference levels on the "floor definitions" dialogue or even better, in section or elevation and right clicking on the selected level which allows you to graphically modify them. But if you mess up, you end up moving everything which is what im trying to avoid.
I am a bit confused.
Are you talking about adjusting the storey levels or the reference levels?
As far as I know adjusting the storey levels will alter existing elements as they are offset from those storeys.
Adjusting a reference level will not move any elements as they are just a 'reference' level.
The value of the element to that reference level will change, but the physical height of the element does not.
Versions 6.5 to 25
Braza
I am probably missing your point, but I think this is not a best practice. IMO First you define Story Levels then you model/position your Slabs with reference that Story Level. If you decide to elevate the whole Story, edit it in any Section with the "Edit Story Level" command. But if you want to change the reference level of a single or multiple Slabs then you edit it individually.
Paulo Henrique Santos, Architect
AC24_INT#3008 / I7 / 16Gb / 512Mb SSD / Windows 10
jl_lt
@Mr. Barry Kelly. Sorry for the misunderstanding. Yes, im only refering to Story levels.
@Mr. Braza. I completely agree in that its not the best practice. But what im talking about is that sometimes you define your levels (i normally do it in 2d cad before begining in Archicad), but once in a while you are in the need to relocate it. If you have already modeled everything in its final position, so i would like to move the story level to match my final slab without messing everything else.
DGSketcher
I don’t think what you are doing is common practice, I may be wrong. Brad gave you a good pointer using the relink tool. I haven’t tried this but you could see if it works for you...
Insert a new storey at the required height.
Turn on all layers
In 3D view use Find & Select in to select all elements that have the old storey as their home
Relink those elements to the new storey.
Unfortunately you will probably loose any 2D associations e.g. dimensions.
The other option is similar to correct the “mess”...
Change the storey height
Find & Select in 3D all elements on the changed storey
Elevate them by the opposite of the storey change
Let us know if this helps or what problems it leaves, it may give GS a better idea on whether they need to look at a solution.
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
Braza
@jl_lt
Just to check: You know that there is an "Edit Story Levels" command inside Section windows, right?
jl_lt
Hi Mr. Braza. Thats exactly the option im talking about. First, whatever you do there is undoable. Then, the option that causes the most problems (for me at least) is the first option (edit just one level leaving the rest untouched). Sometimes, in the flow of the work i end up adjusting slabs by some centimeters, and end up with a difference between that main slab and the associated story level. I want to be able to adjust that story level without moving all the objects.
I know the best practice would be to reposition the main slab level adjusting these options, but i have found this unrealiable specially when working on level changes in the same story. Maybe its a matter of correctly linking the walls to the stories, but so far i always have problems with this. Of couse, when it happens fixing it is quite straighforward, but annoying.
Braza
Hi jl_lt,
Yep. Very frustrating.
IMO You just use this option if your Walls height are linked to story above. So if you increase the Story elevation, Walls will be shorten, and vice-versa. But the Slabs will keep their reference with the Story Level. This is the normal behavior.
Or perhaps you are working with multiple slabs levels on a single Story? Is this the case?
jl_lt
Hi Mr. Braza. Thats right, multiple slab levels in the same story, hence the problems
Braza
Ok. Now it makes sense. Not a big issue for me as I always avoid multiple levels in a single story for accessibility matter. But yes. Your suggestion is perhaps not essential, but also needed. So in my experience I vote Average.
Thanks for your explanation jl_tl.
Nguyen Minh
Graphisoft Moderator
Dear All,
Thank you very much for your feedback regarding this wish, we really appreciate the time you've taken to contribute towards the development of the software!
I am happy to say we took notice of this wish and I have added it to our Wish List database (please refer to it as IDEA-1401). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
