Wishes forum
Multi-shield Layout from PlotMaler 9!
Zdrastvuyte!
I now actively think about a transition with ArchiCAD 9 on ArchiCAD 12. Since ArchiCAD 10, from the moment of built-in PlotMaker, the very useful and constantly claimed function of set of general display disappeared from separate shield!
With the return of every update version I hoped about its returning, but alas!...
Whether will be again realized Multi-shield Layout from PlotMaler 9!?
17 REPLIES 17
Dwight
Ой Vei, хто завжди хоче старі часи!
Dwight Atkinson
Такі да, не треба забувати добре старе!
And it is not! It is needed! on an example:
We print on А0 a display on 6m2 (2 on 3 sheets),
so, say please, how to take into account sizes the "custom sheet" and perekhlest leaves me? Yes, if to draw and place leaves by hand... but why? if PlotMaker 9 did do it correctly, very simply, and main automatically?!
Dwight
Thank you for clarifying. I see the problem.
Dwight Atkinson
Вау! Прогресс! На форуме разрешили использовать кириллицу!
Let's go back to business. This wish is already there. Need only to search.
Do you talk, are already? Is it needed only to find?
Well that, will look yet... Although if present because of "automatic location of drafts on a sheet (net)", it not it!
And again, if am already, why to "hide" this useful function?
P.S. А с кириллицей это - да!
Valery wrote:
http://archicad-talk.graphisoft.com/viewtopic.php?t=22373
This is the same thing?
Aha, thank you! Here also discuss this theme, but on content I see that many began the acquaintance with the products of GraphiSoft with ARCHICAD 10 minimum, and simply not acquainted with this comfortable option of PlotMaker 9...
I hope on support of people, acquaintances with this possibility, and those, who running into a similar problem realized returning of "good old about a necessity" ))
Привет, ArxARV!
An essential wish indeed! I had forgotten AC9 could do it! I hope it will be brought back!
И Вам, Климент, привет!
That, will hope! And to fight!
The MultiShield Layout!
Possibly to someone this function and showed
oneself not necessary...
Now we can see what we are missing!
I am sorry for easy bann, I noticed simply, that a picture is not represented in Opera, but the proprietors of Crome and IE can behold double explanation of problem :0
It's visible in Seamonkey!
Photoshop Elements (7)
Less then 95,00 euro per legitimate license and most editing functions for custom users are included... Do not doubt.
ruthrina wrote:
What is a good, cheap and easy to use alternative to Photoshop?
I want to do stuff like put faces on different bodies and put in backgrounds behind people that weren't there before. Photoshop is way too expensive for me but I've heard that there are some good editing stuff out there. Can anyone tell me of any alternatives that will do what I want it to?
Lord, Photoshop and its alternatives - it is an interesting topic, but here we are talking about MultiShield Layout!
I will now be moved to the AC12, yes, it is better, BUT! still is not enough for this little option ...
Incidentally, the picture that I have laid out below, I shall be in FastStone Image Viewer! (this is not considered advertising)
owen
I actually forgot this had disappeared along with Plotmaker as it occured about the same time I started using InDesign for all my more complicated multi-panel layouts.
Many people still do a lot of this stuff in ArchiCAD though so I agree - bring it back. Essential
(I'm actually doing rough mockups of a 3xA0 competition layout ATM in AC and this would really help visualize the whole. The final pages will still be in InDesign however)
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
