2003-11-04 09:36 PM
2003-11-17 12:52 PM
Link wrote:Maybe I'm misunderstanding you, but it does this now. If you select a 3D view in a view set, notice at the bottom of the view content pane it says "All image menu settings." This includes the photorendering settings at the time that the view is made. As one who has just gone through the process of doing three (existing, two remodel options) identical sets of photorenderings using both normal and sketch renderings (12 renderings in all). Let me just say, make sure you use ACTUAL cameras on the floor plan
Please GS, make it so that ArchiCAD's Navigator can remember the photorendering settings assigned when the view was made, so that we can import different styles of rendering into one layout book.
2003-11-17 01:44 PM
Link wrote:This bring us to the point : we need 3D display option combination as AC8.1 brought for 2D display option :
As it stands, if we import two different styles of renderings into PlotMaker, by way of saving the camera view (using photorendering window), then only the current AC photorendering settings will be used.
2003-11-17 05:18 PM
2003-11-17 05:21 PM
2003-11-17 08:48 PM
Link wrote:No time to test at the moment, Link, but did you try my old tip for creating your own sketch settings?
Just to clarify my wish:
It would be great to have 2 different sketch renders in the same layout book. Additionally, it would be great if we could save those two renders out using our own defined (and stored) sketch settings.
2003-11-18 06:28 PM
See:Karl - I don't think you deserve a mug or t-shirt for that tip. You should be given an award for ArchiSTUD of the year.
http://www.escribe.com/software/archicadtalk/m25283.html
No mug or t-shirt for that one.
Given a custom preset - will it not be memorized as part of a view setting and solve your problem?Unfortunately this does not solve the problem. Even with separate custom presets, only the current engine/sketch style is used when regenerating the view
2003-11-18 09:46 PM
Link wrote:Ouch. Saw Djorjdje's note to the same effect today. Definitely stinks ... hope you'll start a thread on the wishlist for this if you haven't already.
Unfortunately this does not solve the problem. Even with separate custom presets, only the current engine/sketch style is used when regenerating the view![]()
2003-11-18 11:16 PM
Also have seen weird lines coming from the model and heading off to infinity.Hmmmm... well I haven't seen them vanish off into infinity, but I have seen them between certain windows (W2 Horizontal Slide from the Windows 81 Classic folder, to be exact). See the attachment - you may have to click on it to see it properly.
