2006-07-26 09:34 PM
2006-07-30 01:20 AM
2006-07-30 03:49 AM
"matthewjj" wrote:
... like when you select items in the publisher it should automatically select the 'Publish - Selected Item'. How many times to I have to abort an accidental priniting of 50 sheets???? Please!...quote]
Yes, i have the same problem, very annoying.
2006-07-30 02:11 PM
Mark wrote:riiiiight. but how the hell is archicad supposed to know that there has been a change if there hasn't?!
What should happen is if the pen is changed to the same pen, all selected elements should change to this pen.
2006-07-30 02:29 PM
2006-07-30 02:41 PM
s2art wrote:yep. good idea. a bit like the apple iTunes 'edit multiple info' dialogue . . ? if you change a 'parameter' the little box next to it shows with a tick.
IMHO the setting should display as "varies" then you only have to make one change. Also highlights where you may have set something incorrectly if you have a "varies" come up and all items should have the same setting.
Subject | Likes |
15 | |
14 | |
11 | |
11 | |
10 |
