Wishes
Navigator Improvement - Transmittals
DGSketcher
Legend
Currently the Layout Book view highlights any drawings with changes, what it doesn't do is differentiate those that are changed but are "Not in Transmittal Set" if a Transmittal Set is open. Currently to ensure all relevant drawings are included it is necessary to step through each Layout and check for the NiTS status.
If a Transmittal is open and an update is run, it may add changed Layouts to the Layout Book list but it won't add them to the Transmittal Set. This is correct behaviour. But as users we should be made aware with a visual clue e.g. a change of text colour, that a Layout is changed but is not included in the Transmittal Set, so that the user can add it if required. Stepping through a 100+ drawings to spot NiTS issues isn't very efficient.
0 REPLIES 0
