2020-06-20 05:24 AM
2020-06-20 09:16 AM
2020-06-22 02:29 AM
2020-06-22 03:01 AM
2020-06-22 03:50 AM
Jp1138 wrote:No. Nested CP's are available only to CP's and Nested Composites only for Composites. No mixing here.
do you use in in composites, where instead of a building material you can choose another composite / complex profile, for example? Complex profiles within complex profiles can be a bit tricky, maybe there should be another way to assemble the parts?
2020-06-23 10:41 AM
2020-06-23 11:11 AM
2020-06-25 10:15 AM
2020-07-02 04:31 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-07-06 01:45 AM
2020-08-12 05:59 AM
2020-08-12 07:26 AM
2020-08-12 08:55 AM
2020-08-12 09:39 AM
2020-08-12 10:11 AM
DGSketcher wrote:That is for sure!
but be assured when it does go wrong GS won't be footing the bill for poor data management.
2020-08-23 02:24 AM
2020-08-24 01:21 AM
bouhmidage wrote:I like that idea from a consolidation perspective. A lazy fix might just be to make the wall skins in a Composite parametric. I wouldn't mind that, as I still haven't fully grasped the CP stretch set up, but I also think of CPs as more component orientated e.g. beam / column type elements. Overall though I would back their consolidation if the modifiers were better explained or easier to use.
i was thinking why not merging the Composite and complex profiles together...
2020-08-24 02:52 AM
DGSketcher wrote:+1bouhmidage wrote:I like that idea from a consolidation perspective.
Sun Aug 23, 2020 9:24 am
2020-09-10 03:17 AM
