Wishes forum
New GDL commands such as LOFT are long overdue!
Jarrod Phillips
It would be great to see some new GDL commands such as loft added to the GDL library. I know I’m not the first to request this but I believe a loft command would add some much needed functionality. Some other variations of loft would also be useful such as lofting two shapes (1 at each end) along a non linear path. E.g a lofted elbow with a circle at one end and a square at the other. It’s one command that has the potential to create a handful of complex geometries that’s required in a lot of contemporary objects.
Cheers!
Jarrod
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 26
1 REPLY 1
runxel
Ace
Valid request. I'll mention RULED and RULEDSEGMENTED here, because that is already very close, but sadly does not allow arcs (which is kinda understandable). And that's a wellknown limitation of GDL, too (Tube anybody?) – which means, if you know how, it can be overcome with a bit of math. Still a less verbose way would be very nice indeed!
Tangent to this: Even more powerful would be a SWEEP2 like in Rhino, where you can sweep a surface between two rails, which allows for many forms to be realized.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
