Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
New standard (obligatory) parameter of materials in zones.
I want in the GDL editor for zones were standard parameters coatings (materials) bounding surfaces. In the 3D window, zones knows bounding surfaces, why not in the library part.
I understand that this will be an array of values. Ideally, this three-dimensional array - the first column - the walls, 2nd floors, ceilings, third - all the trimming.
Also the wish from fantasy area - have access to the arrays in schedules and lists.
Even if it can not be done in the schedule, but the GDL programmers will be able to get these values to output in a single parameter.
So, ideally, the surface area for each material.
0 REPLIES 0
