Wishes forum
Non-printable layers
gerald lock
I can't seem to find a topic about this, so here goes...
Currently, each layer has a lock/unlock and a visible/invisible toggle.
How hard would it be to add another toggle to make a layer printable/non-printable?
Every other 2D drafing app I've ever used has this function, and it's great!
Could you add it to the next build? or must we wait for the next version?
NMA Architects
3.2MHz Pentium(R) D/XP Pro/ArchiCAD 11.0
gerald@nma.net.au
19 REPLIES 19
Matthew Lohden
It would be handy to make visible layers non-printing, but since it would still presumably be governed by the layer combinations it wouldn't serve as the sure fire way to keep certain layers from ever printing. It also runs counter to the wysiwyg principle.
Matthew Lohden
Consultant, SF CA
MacPro 8core 32GB Radeon 5870
OSX 10.8 Mountain Lion, XP32, Win 7x64
gerald lock
To provide a "constantly non-printing" layer, would surely be a simple as the current "constantly-visible & unlocked" [ArchiCAD Layer] - I've been told that AutoCAD has one (called DEFPOINTS I think)
...or one could simply adjust Layer Combinations setting to suit (both options would be good, giving max. flexibility)
As far as WYSIWYG principle goes, ("what you see is what you get" for readers of this thread not familiar with the acronym) it needn't be compromised - non-print layers could become either "ghosted" (but coloured separately from the ghost storey colour) or a pre-set colour. Currently, ghosted storeys don't print unless requested. This idea could behave in the same way.
NMA Architects
gerald@nma.net.au
Michele
I loved the defpoints layer when we used autocad. We could put things on a layer that would be turned off and not print a white blob over everything. Ahhhh..... one of the good things about autocad.
AC10/12 USA 11882156, OS XP 2 GB Ram
Erich
The nice thing about a non-printing layer is that you can use it to provide information to the user without worrying if it will show up on the eventual output. Other than that it is not really necessary to Archicad in my opinion. (12 years using AutoCad) Still it is a common cad tool and I was a little surprised it wasn't present when I made the switch to AC.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Erika Epstein
Every time someone suggests the non-print layer, I can't help wondering how are you using this program that you feel you need one? What are you drawing that shouldn't be printing?
Need to leave notes for co-workers? use the mark-up tool or FILE>INFO>PROJECT NOTES
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Gustavo Mur
I strongly recommend DO NOT ADD the non-print layer function as Autocad Uses. I used Autocad for a lot of projects. It is a constant font of frustrating mistakes on documentations.
Archicad is a superior program with a lot more tools and much simpler ones.
We do not need such a thing. Please! As list is my point of view.
Albaisa+Doval Architects
Miami, Florida, USA
Ex Minicad-Vector Works on Mac
Ex AutoCad 2000-2006 on PC
Archicad 9-11-12 on PC
kliment
I wish I never see a nonprinting layer option in AC!
According to me everything seen on the desktop should be printed! If not, it should not be on the desktop! Simple!
The old Autocad thinking has to be forgotten!
The Defpoins layer in Autocad is needed mostly for storing Points (the alternative of Hotspots), especially when using Blocks. Well, Hotspots are nonprintabe in AC!
Kliment Ivanov
http://www.klimentivanov.com
AC /since 4.55/; AutoCAD; Max; SketchUp; VRay; ArtL; Photoshop; Illustrator; InDesign; CorelDraw
Win 7 Ultimate 64
OpusMCK
I also found it surprising that Archicad did not have a
"non-printing" layer. The other Cad programs that I use have one.
It's not something I use everyday, but it's useful.
The others that I've talked with who have only used Archicad
didn't know it was possible but would love to have one.
Our feeling is that for Archicad to add the layer and those
who don't want it don't have to use it, but it won't ruin the
program to add it for those
who would like to have it.
Thank you.
AC10 MacIntel on an I-Mac, 3d Studio release 2009, AllPlan, Autocad, Photoshop, Flash, Vista 64, and so on. . .
Architectural 3d modeling and simulation.
skywalker86
I agree with adding a printable/non-printable layer as this could be used for complex 3D models which would otherwise slow down your model/work space, and have the option to only display these models when printing. Just my 2 cents worth. Not sure if anyone has had this issue where a downloaded object is slowing down your workflow significantly? I am currently having this issue.
Da3dalus
Dead Topic.
I think this Wish has been superseded by the advent of Trace References, persistent Guidelines, Snap Guides, Graphic Overrides, and more On-Screen View Options than you can shake a Morph at.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 23 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.14.6 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
proto
...resurrecting this thread...
Another former acad switcher/beginning Archicad'er here that is wondering about non-print in Archicad...In acad, non-printing layers was a great way to set up drafting conventions to keep a sheet organized. I see, tho, that they are not supported.
What do people do to create nice clean drawings where the notes across details/elevations line up on the page and reference titles have a consistent relative positions.
I'm doing my first project, and I'm frustrated by the apparent looseness of placing views on sheets just eyeballing things...is there a dimensionally accurate process for these things?
Followup drafting convention question: When working in 2d for details & interior elevations, is it conventional wisdom to create individual views (1 per dtl, or 1 per int elev) or just draw whatever 2d views on a sheet layout as a single view (like all four sides (int elevs) of a given room)? Or even all the interior elevations on a sheet view?
Thanks for your patience with these very basic questions.
learning on mac v25/US solo, Big Sur 11.6, 2020 iMac
@proto Chuck gave one response in the last post before yours - Trace Reference, Guidelines, etc.
But, of course, any layer that is not on is non-printing at print time, right? 🙂
So, you can certainly use layer combinations when you are looking at layouts if you really must have actual guidelines/etc or some type of template to snap to... but you can also use the hotspot tool to place snappable hotspots in a Master that are viewable in all layouts using that Master.  Hotspots never print.  Ditto guidelines as Chuck suggests.
Layer combinations for the layout (including the Master) have no impact on placed drawings.
"Never" draw anything related to the project when you are in layout mode.   For the details and interior elevations etc you want things to be 'live' and derived from the model as much as possible, so, yes, a placed view (which becomes a 'drawing') for each detail and elevations.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6, iMac Pro
hotspots - how do these get used? [i did look them up, so I understand what they are but do not understand this new strategy for documentation...maybe just an example, i'm guessing there are many ways to use them...]
"Never draw anything related to the project when you in layout mode."
OK, but how do people coordinate between details/elevations that end up sharing space on a layout?
ie notes lining up, avoiding linework overlapping, coordinating sizes/shapes of views that will share space on a sheet
i'm familiar w/ guidelines from Adobe products & those make sense
i understand how trace works, but not sure how trace applies to this issue of layout coordination
thanks for your assistance,
If you go to the Master Layout Settings, check out the "Drawing Placement" panel, which has two options for the automatic placement of Drawings on Layouts. Here is the Help Center page discussing them:
https://helpcenter.graphisoft.com/user-guide/137577/#XREF_22630_Arranging_Multiple
https://helpcenter.graphisoft.com/user-guide/137981/#XREF_69281_Auto_Arrange_New
https://helpcenter.graphisoft.com/user-guide/137981/#XREF_13489_Align_and_assign
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Not sure this is really addressing the issue [aligning content between views, as opposed to just getting views to be organized on a layout], but I will read up on these & see what I am missing, thank you, laszlo
For aligning content between two Views or a View and a Drawing placed on a Layout, the Trace Reference is the best tool.
Thanks, Laszlo, I will go back & review that tool more thoroughly.
OK...Trace is a revelation!
That's what I needed...
@proto For manual placement you can drop your layout views on the sheet and then you can either move/drag the views with the "viewport" corners or you can use points within the view as base and reference points.Make sure you use the correct Move option from the context menu, one moves the whole "viewport" the other option repositions the view within the "viewport"
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
