Wishes
Open / Edit / Cut (at Point/local) closed Polyline Facades
Romans
Please provide a method to open/cut polygonal (closed) facades.
Thanks.
Apple iMac Pro with macOS Sonoma, AC 5.0 to 27 INT and GER, all the latest
runxel
Legend
That's already working, but quite counterintuitive.
There is a seperate command for splitting curtain walls ("facades").
However, you will need another (dummy) curtain wall.
So:
Draw the dummy CW.
Select the CW to split.
Use the dedicated CW-split command.
Now select the dummy CW. This will be the place where your main curtain wall is cut.
Works with closed CWs as well.
Romans
Thank you.
It is a little quirky that a CW only can be split by another (dummy) CW.
Also, the split does not happen only at the location, all CW-parts inline with the splitting CW will be cut.
See also the image attached.
So therefore it would be great to get this function improved.
