Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Opening composite settings
Yvonne
It would be super helpful when we open composite setting for it to jump to the composite selected.
Something similar to building materials when the building materials within an element is highlighted.
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
Lingwisyer
Guru
If you right click on the wall / slab / column / etc, there is an option to "Edit Selected Composite / Profile".
Ling.
1 REPLY 1
Lingwisyer
Guru
Ling.
