Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Other 3D Softwares Best Features you Wish in Archicad
Rakela Raul
This might be more effective than the wish list that seems out of control and hope
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
18 REPLIES 18
Some that cross my mind immidiately!
1. Revit's temporary dims (select the object and see dims attached to its extends and changing those values changes geometry)
2. Some of revits relational Capabilites.
3. My favorite of course is SketchUp's Pull-Puss and face creation strategy.
Its simply AMAZING and most of all intuitional
Rakela Raul
ability to copy/ rotate or manipulate i should say, 3d elements in sections / elevations, wd be one of mine...
other wd be having the option of several screens within one screen (elevation, iso, plan)
Petros Ioannou
My wish is for GS! Get a copy for each software along with a power user of each. Don't let AC programmers get near it! Possible infection!
Give him various tasks and watch him in action!
Posting specific application feature(once again):
ADT's Curtain wall system .Just fantastic!
Combine ArchiCAD's door-window system with archiglazing, window-door builder, storefront windows, curtain-wall objects or anything else you have seen adding the possibility to customize each mullion,infill,profile etc
A little hard to understand at first but once you get it, works like a charm!*
Petros
*these are just my words. Try to see it in action by someone who really knows how to use it
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Rakela Raul
i agree.....
any decent feature from 'allplan', 'idecad', 'vectorworks' ???
Stephen Dolbee
I agree. Much more versatility is needed. Without Door/Window Builder, my job would be much more difficult. Archicad windows should be just as good right out of the box. No, they should be even better.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Rob
Sorry oreopoulos,
but this is a feature that I wouldn't appreciate at all. It's so annoying and disturbing when working with Revit (in fact when "fiddling" with Revit).
However this is my wish: A simple built-in tool for a profile/curve extrusion along 3D curve(s).
::rk
Scott Davis
Sorry oreopoulos,
Revit's temp dims are a very nice feature. Temp dims can become permanent dims with a click, and all geometry can be controlled by highlighting an element and changing its dimension, wheter temp or permanant. Even dimensions in Revit are bi-directional parametric. It's a tool any 3D arch software should have.
As for it being annoying, well, thats just a part of letting go of old habits, and embracing new technology.
Scott Davis
Autodesk, Inc.
On March 5, 2007 I joined Autodesk, Inc. as a Technical Specialist. Respectfully, I will no longer be actively participating in the Archicad-Talk fourms. Thank you for always allowing me to be a part of your community.
Sorry oreopoulos,
Temp dims are a visual aid. It could be turned ON and OFF. As simple as that.
I find myself all the time drawing lines to measure length of walls. OR changing the origin to create a wall at "x" distance of the walls start. OR...
I Undestand that you may find annoying, but such a feature can be TURNED ON or OFF and everyone can be happy
1. NURBS objects - meshes, surfaces, etc.
2. Abillity to open several different files in tabs. Every application has it!
3. Built-in INTELLIGENT calculator that works within the type-in fields.
4. Rotate in Section and 3D.
5. Arcs in Section.
6. 3D polylines and lines.
7. Resizable Pallettes and Toolboxes.
to be continied...
