Wishes
Other 3D Softwares Best Features you Wish in Archicad
Rakela Raul
This might be more effective than the wish list that seems out of control and hope
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
18 REPLIES 18
Rakela Raul
so far all features mentioned here are beyond important to me.
i wd like some modeling tools that microstation has.
Djordje
Ace
oreopoulos wrote:
I find myself all the time drawing lines to measure length of walls. OR changing the origin to create a wall at "x" distance of the walls start. OR...
Use relative coordinates, man ... no need for relocation of the origin.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djorje
I do use relative coords.
Draw a wall.
Then you need to draw a wall 3m from the start of the wall.
How do you do it if not moving the orign.
I have the Relative coords pressed but i need to find the starting point of the new wall. Not create a wall AFTER i found the starting point.
Rel Coord work AFTER i have started the operation of wall creation.
Did i understand wrongly?
Djordje
Ace
Seems to me you don't ... 😉
oreopoulos wrote:
Draw a wall.
Units are meters.
Place the cursor on the start of the wall, type x3+ and press enter.
For another 3m to the right and 3 above type x3+ enter y3+ enter.
Maybe; the language can be misleading
Djordje
HP Omen
I do
oreopoulos wrote:
Units are meters.
Well here is my MISTAKE.
I thought that when the relative button is pressed the coords that i input are RELATIVE. THere are not. The + symbol in the end makes them relative. But when i have started a wall then the + symbol in the end is not neccesary. Just x3 and or y3 will suffice.
Thx Djorje. No need to move the user origin
Thanks too, Djordje, I did't know that + trick!
There is a feature in AutoCAD that I like very much and I think it will be very useful in AC too:
You start drawing a line/wall/circle, press Shift to determine the direction and type the distance. No need to press X, Y or R, because the direction along the axis is already determined.
Balazs Simonyi
I have splitted this topic, because it became really offtopic.
Continue here.
Balazs
Djordje
Ace
Press A to lock the angle you started drawing at, R to type the distance.
Djordje
HP Omen
I know this, Djordie!
That's why I point it out that the AutoCAD way IS better!
Trere is just a small difference between the way the two applications do it but when one uses these commands a lot it matters.
