Wishes
Overhauled Hotlinks
I would like to see a complete overhaul of the hotlink modules.
It should be possible,
- to create external and Internal Hotlink Modules (like Rhino Blocks). (without iceberg methods etc.)
- internal Hotlinks should be openable (like the edit mode for complex tools)
- so we could change the module,
- add or delete things from the module
- after closing the module all changes all other instances of the module should be updatet of course
- the creation of Hotlink Modules should be possible from any view
and not to forget:
it should be possible to display hotlinks with another LOD than the host project! (proxy view)
There have been several wishes about this. For example, here is one about internal hotlinks, which has quite a few votes:
https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=49122
