2004-01-09 08:54 PM
2004-01-09 11:28 PM
2004-01-10 02:04 AM
Matthew wrote:The white lines attempt to make it fail proof. Alternately you could use lines of any color, put them on a unique layer and use a layer combination to hide them before plotting. One downside is you might forget and mess up your plots. Another is they're always visible (unless you hide them) even if you'd like to get a print preview like representation on screen. Which makes it a multi-step process when one goes back and forth.
I must say that your approach is a very clever work-around. I'll probably start using it myself (since I rarely show the masters in their true colors).
2004-01-10 03:11 AM
