2020-09-14 12:25 AM
2020-09-20 01:59 PM
2020-09-22 12:21 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-22 04:03 PM
2020-10-16 04:50 PM
2020-10-17 12:23 PM
2021-10-22 07:05 AM - edited 2021-10-23 06:07 AM
Just starting out with PARAMO. Great tool. Below are a few additional ‘wishes’:
> Imperial units option in WE (or a setting or function within the editor).
> Greater decimal places to the right in values and steps. Small objects are showing a lot of “0.0” values in editor mode.
> More object view rotation capability in the preview pane. I am finding it hard to see small shapes under a larger shape when the larger shape is close to ‘ground’. (Setting surfaces in ‘glass’ helps, but I need to see my shapes are meeting together correctly underneath.)
> Zoom value box for node editor window.
> Hotspot tool within the editor (if not already provided somewhere in the editor).
> Greater Help documentation; maybe with examples of application for the non-intuitive nodes.
Also, if a goal is to be able to create object arrays (as shown in one of the GS videos), it would great to be able to choose varying layer values for the associated/referenced objects.
