Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Partial Structure Display for stairs
Yvonne
Considering we can change structure (which is pretty much the core) and finishes, it would be good to be able to display construction elements in the stairs using on the partial structure display like you would a composite (wall, roof etc).
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Yvonne,
Thank you very much for creating this wish!
I am happy to say this is an existing wish in our Wish List database (please refer to it as Wish #11500). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
The italian Archicad guru Matteo Paiano solved the problem with a couple of strings of code into the riser and thread gdl object...nothing more...nothing less...
Schermata 2021-12-12 alle 21.31.42.pngSchermata 2021-12-12 alle 21.32.00.png
