Wishes
Permanent Guide Lines - create new guide line relative to ex
Thank you for the permanent guide lines. After positioning a guide line how can I place another guide line at a given distance parallel to the first. If I move it nothing stays behind. If I grab another one from the side - place it on top and then move it they both move (or the one cancels the other out). I have read through the help center and don't see anything that deals with this. I have also tried various combinations with the ctrl, cmd and shift keys to no avail.
thanks
James
4 REPLIES 4
Eduardo Rolon
Use CMD+Drag and type the distance just like you would do for a wall.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Stress Co_
Hover over the Guideline until the orange ball appears.
Drag the ball and press the alt/option key
so the + sign appears. It'll drag a copy.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
Got it - thank you Eduardo. And I also learned that you can Cmd-D + alt on the fly with walls. I have only ever selected them first and then typed Cmd-D + alt - which I couldn't do with the guide line
Thanks
James
Even better - thank you Marc
