2009-03-05 01:54 PM
2009-03-05 05:01 PM
2009-03-05 05:40 PM
Erika wrote:I suspect he means the rectangular area each view opens up in, i.e. an on-screen window, not a window on a building!
Huh?
Sorry, but I can't follow what you are asking. Windows don't have a layer combination; the walls they are placed in have a layer they are on
2009-03-05 06:34 PM
2009-03-05 08:09 PM
Peter wrote:Why not use Virtual Trace for toggling between views?
The ability to just click into an elevation view that is already open (but in the background) from a plan, without the layer combination changing would be great.
2009-03-05 09:38 PM
Laura wrote:Yes you could to some extent, although it would prevent you from displaying an overlayed plan as well, which is the main purpose I use it for. I generally use Virtual Trace for little more than how ghost storey used to work, as in just referencing other storeys above or below the current. I know how it works and what options are available, I just haven't found a way of integrating it better into how I work. Perhaps I should just experiment more with it!Peter wrote:Why not use Virtual Trace for toggling between views?
2009-03-06 02:45 AM
2009-03-06 02:55 AM
Virtual Trace doesn't help - try placing a trace reference with different layer combo in current window, then click "activate reference" to edit something in that reference - sure enough a new window containing that reference appears - but then try clicking back on your original window... - You will find the wrong layer combo is now active for that original viewIMHO it's a bug rather than an intention. I would report it.
2009-03-06 03:13 AM
2009-03-06 04:59 PM
Paul wrote:That's because this is the wrong process. Click on the "Switch Reference with Active" button on the Trace & Reference Palette to access the Reference, and again to return to the Active. Also, I suggest working in
try placing a trace reference with different layer combo in current window, then click "activate reference" to edit something in that reference - sure enough a new window containing that reference appears - but then try clicking back on your original window... - You will find the wrong layer combo is now active for that original view, so you still manually need to reselect desired layer combo & other display settings & regen that view to continue working. Then you need to do it over again every time you need to edit in another view window
