Wishes forum
[Poll] Label ability to add pointer to top/bottom
Started a topic thread on CDs about how to add leaders and pointers to the top and bottom of a label. Without programming knowledge the only way to work this is creating two different labels then grouping them.
http://archicad-talk.graphisoft.com/viewtopic.php?t=53372
10 REPLIES 10
DGSketcher
It's great when people create polls & then don't bother voting! Although there's a few politicians who probably shouldn't either...
Apple iMac macOS Monterey / AC26UKI (most recent builds)
I didn't want to sway the electorate. 😉
I second this. This issue can't even be resolved with programming knowledge. GS needs to add an option to attach pointer to the top and bottom of the label. As it stands now, the only variable available to us is "LABEL_ANCHOR_POS" and it only allows us to attach a pointer to the left or right side of the label (not top or bottom).
You should always vote in your own poll.
Voted.
Lesson learned.
ESP182 wrote:
Voted.
Lesson learned. 🙂
If I where to create a poll, I would, probably, vote "Essential", not "Important"... as it is essential to me, as the one having a problem.
Noob question (you can tell I've posted <100 times) can you change a vote? Or is it set in stone?
If the number of posts is the defining metric — I am no expert ether, but I don't think there is a way to recall a vote after you voted.
I have voted Essential on your behalf, although I rarely use the Label tool - I prefer to use text and a polyline for the arrow.
Thanks!!
No, it is not possible to change your vote once you cast it.
The forum software does not support it.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
