Wishes forum
Prevent locked objects from being selectable
Tomek Piatek
When working with a busy model it is often difficult to select the right object/element. Tabbing through the available selection candidates sometimes doesn't work and it takes a bit of zooming in and out to finally get at the right thing.
Other times we have some objects whose shape and position has been set and locked and they won't change. Selecting those elements doesn't make sense most of the time.
It would be really helpful if there was a way to disable selection of locked items. This of course would be a toggle option of the selection process.
Pushing the boundaries of local time/space continuum since 1972.
Archicad 26 | iMac (Retina 5K, 27-inch, 2017) | 4.2 GHz Quad-Core Intel Core i7 | 24 GB | Radeon Pro 580 8 GB | macOS 12.6
14 REPLIES 14
For this reason I generally work with the terrain mesh layer off, or with it on it's own story.
Win10 | R5 2600 | 16GB | GTX1660
It's too bad that the poll is gone (it is on the old archicad-talk forum), but at least according to Minh this is #11816 in the wishlist database...
I find tabbing fine...but I, too, would like locked elements not to show up in the tab sequence = the original wish of locked being not selectable.
It seems to me (at his moment anyway) that the only reason to 'select' a locked element would be to use it to populate the Find & Select fields... but that can be done with the eyedropper.  And speaking of the eyedropper, that could still be used to pick up the tool and element settings even if the locked element could not be selected just by eyedropping over a hotspot... which is a non-selecting operation.  Similarly, drawing a selection marquee around elements that include locked elements should just ignore the locked elements.  At least that's my interpretation of the 2 year old wish, which I think would be useful. 🙂
And, then the issue of needing to select to unlock... as Tomek said, you untoggle the 'locked elements are selectable/or not' toggle .... which I see as being very similar to the 'suspend groups' button.  I could see an icon of a padlock with hotspots around it for the locked items are/are not selectable.
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
yes of course, but in a certain moment i have to switch on the layer...and is a mess only moving the cursor...
runxel
Ace
This is one of the things that bewildered me the most when I started with Archicad.
I think AC is the only program to ever have this quirk. Very unnatural, I have to say. Also makes the onboarding process for new users difficult.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
You know what would be really awesome? If GS published at least a read-only list of all the wishes in their secret squirrel database. Wish #11816 doesn't mean anything at all. Being able to see the wishes that have been selected though, now that would be something.
