Wishes
Publisher - Open Published Documents Folder
Miha_M
One small wish for Publisher UI. After the publishing process in the UI Window, which states "Publishing...(X/X done), some additional buttons, or right click context menu options should be added.
The purpose of this command should be:
1. Open published document,
2. Open published documents folder.
| Archicad 4.55 - 27
This can already be done since at least version 23.
Then you can open it from there.
Miha_M
Thank's Barry! I didn't notice that. What a great addition! So simple, but so helpful.
| Archicad 4.55 - 27
