Wishes
Publisher Set Properties window rearranged
Emre Senoglu
This is a minor detail, but one I am reminded of each time when publishing a drawing set. The option to chose published file format is all the way below after all the irrelevant settings. Format could be up with publishing method. It makes no sense to me the format option is after name and path.
AC26 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
www.senoglu.dk
1 REPLY 1
Hi Emre Senoglu,
you are absolutely right.
Further I would like to may MASTER decisions as user.
E.g.:
PDF:
- I don't like "Project info" in project. It is my user decision and I have to make it every time I generate an other PDF. I would be very pleased, if I could do this once an than I can forget it.
- Same regadring picture resolution in PDF-files.
Best regards
Mario
