Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Purge function in Library Manager
I've often found on projects that have not been managed properly that there are a large number of unused .gsm in the embedded library.
There should be a 'Purge Unused' function as per the attribute manager.
7 REPLIES 7
I agree.
This is especially a concern when doing interior design with dozens of high-poly .gsm models imported from Sketchup 3Dwarehouse.
philips wrote:
I agree.
Same Here!
Erwin Edel
While not excactly what you are asking for, it is possible to see which objects are being used and if you select individual parts in the library manager you can delete them and see if they are in use as well. This might be helpful, while we wait for ArchiCAD 23 to implement this 😉
Allthough a blind purge button is quite dangerous for inexperienced users I would say. If I have several stairs that I am trying out during design development and a colleague just purged the ones I wasn't using in model, I'd be a bit annoyed.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Pertti Paasky
Good idea. Purge is good when finishing the project. Also when making templates. Not to mention cleaning the project. When dealing with big projects this is more important.
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Da3dalus
Definitely essential. We get a LOT of parts added when we import IFC models from consultants.
Since IFC doesn't completely understand parametrics, it has to import every instance of a structural member or a plumbing fixture as a separate object, whether or not there is any variation. Otherwise the geometry may be wrong.
Also, it just gives ex-AutoCAD users another thing to complain about: "AutoCAD had PURGE way back in 1985." I don't want to hear it.
Saving as a PLA Archive is NOT a good answer, especially fro Teamwork files. Clearly it knows how to sort out unused Parts, please just simplify!
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
Whilst I agree, this could be managed with user profiles in teamwork and thinking about it, no longer applies to stairs from AC21.
alemanda
Saving to PLA is like purging ... isn't it?
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
