2022-01-15 04:14 PM - last edited on 2022-10-04 12:37 PM by Oleksandra Vakariuk
A Big wish would be to have a Re-use option/ phase in the Renovation. Many offices are looking to re-use building elements in order to achieve a more sustainable built environment.
A nice green color would be great to document which elements are meant to be Re-Used in a different position or another project. The Craftperson/ demolition crew will have a clear understanding of which parts to handle with extra care and put in storage. Adding a green Re-Use option to the already great Renovation red and blue scheme would also make collaboration in planning phases much more smooth.
Hope it's possible
Best Regards
Eske
Solved! Go to Solution.
2022-02-09 09:57 AM
Hi All,
Thank you very much for sharing this great idea!
I am happy to say we took notice of this wish and I have added it to our Wish List database (please refer to it as IDEA-9222). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-01-24 08:32 AM
I totally agree with this! I think I've made this wish long time ago!
I somethimes come across projects that we change the floor and we reuse the radiators in different places.
2022-02-09 09:57 AM
Hi All,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2022-02-09 10:18 AM
Hi Minh
Great to hear 🙂
Thanks and you too!
Eske
2023-04-19 02:19 PM
I would also suggest a "renew" option for elements that stay in place and need some simple changes.
For example, if I want to renew an existing wall, may be I will change it's composite or just paint it with an other surface.
Many many times, I want to change some settings of a door or window from existing to projected phase. In reality, to change for example the handle of a door, we will not destroy it, rebuild the wall, then create the same opening and put a new frame and door...
Current workoround is to duplicate the element and edit the changes. One is setted as "destroyed", the other as "new". Then it appears in demolition plans and scedule or in construction plans and scedule, but in fact it souldn't.
One question is : Which changes can be accepted in this "renew" option ? All possible changes ? Or just some of them ? How far could it be possible and logical to edit a renewed element ?
Anyway, I believe this "renew" (or change) option could be as interesting as "re-use" is.
Re-use : keep settings and change location.
Re-new : keep location and change settings.
Tinou.
2023-04-22 03:12 PM - edited 2023-04-23 08:30 PM
Hi @Eske I actually think I have a workflow that solves this request / question using the built in Archicad's current tools.
I bookmarked your post some time ago because I had the same question as we do a lot similar renovation projects. And @Tinou's very relevant comment expanding the application of this request / question, brought this post back to me.
My workflow is quite simple:
While we wait for Graphisoft, I started testing this workaround and it actually works just fine and it's actually easy. Here's how I set it up:
The "Graphic Override Rules" are triggered by the "Status Property" setting which gives you full control of all the different element statuses. You can even use the "Status Property" as "Criteria" for "Schedules". I have been using this setup as part of my template since Nov 2022 and it is predictable & stable.
This very clever video by @John Halgarth from CONTRABIM takes the Renovation Filters far beyond the usual and gave me a lot of ideas for this workflow.
CONTRABIM - Using the Renovation Tool to Create Multiple Design Options
https://www.contrabim.com/blog/using-the-renovation-tool-to-create-multiple-design-options
And we might not have to wait for that much longer. We can now look forward to Graphisoft's solution for this request, hopefully in Archicad 27 as listed on their "Graphisoft Roadmap: Coming Soon - Design Options".
2023-04-24 10:36 AM
@Francois_MCD Thank you for your elaborate workflow description. I will test it as soon as possible.
