2016-05-04 06:36 AM
2016-05-04 04:56 PM
2016-05-04 05:22 PM
laszlonagy wrote:Does this mean that NURBS are now new GDL commands and it will be possible to write with text an object with real NURBS ?
That preview you saw are real NURBS, since NURBS are now implemented into GDL in ARCHICAD 20. However, NURBS modeling is at this moment still not implemented in ARCHICAD modeling with construction elements.
2016-05-04 05:48 PM
2016-05-05 03:36 AM
laszlonagy wrote:Thats sounds great if this is the future! So the imported objects are real NURBS but just the graphic appearance can be adjusted from segmentation to smoothness? I see that initially the surface is still like a faceted mesh and changes with the new settings.
2016-05-05 03:17 PM
2017-05-18 09:01 AM
2017-05-18 04:00 PM
Constantin wrote:Same thinking here, I also hope they are working on something bigger, ARCHICAD is the only BIM software that is using segments instead of real curves so far, if I'm not wrong. This is a long wish for me, I am not working on organic building shapes, but the segmentation affects me on the modeling and documentation of the projects.
I`m just wondering, how difficult would it be to completely switch to nurbs modelling and display in GDL as well as for the construction elements? Would it require to completely re-write the whole modelling and display engine?
I am not saying that everyone needs to design and fabricate complex double-curvature surfaces but at least to be able to use splines in extrusion profiles and paths, for PRISM, TUBE, etc
I don`t quite understand the current NURBS implementation in GDL, since they cannot be used in the modelling and they don`t even display as such. Is like the information is there but you cannot use it. Or they are just the first step towards something bigger...
2017-05-20 10:25 AM
2018-02-05 08:01 PM
