2004-01-20 09:52 AM
2004-01-20 09:12 PM
Geoffroy wrote:I agree - since we first locate the objects via our library folder structure,
When defining an interactive schedule or any custom schedule in the calculate menu, if you want to add parameters of object, the choice to get theses element must be made by selecting the object first.
To select the objects ArchiCAD will present a partial tree view where all the elements will be listed but nearly unusable : they seem to be sorted alphabetically but with an hidden folder structure (see screenshot)...
Can't the real library folder structure be used ?
2004-01-20 09:58 PM
Karl wrote:Yes, bu it will only work with newer libraries (made with AC8)... so it's still a mess with older library parts, as they are all on the same level
Another option that we have that helps track down a hard-to-find library part in the I.S. is the show "All Types by Subtype" as shown in the attached.
