Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Reference Levels Smarter with Display Capabilities on Elevations, Sections & Interior Elevations
It would be good if:
you could create multiple reference Levels that could act as stories in section, where you could set the desired elevation and have it populate a dashed line in 3D generated views. Creating Stories is a good work around, however I would much prefer to keep the model simple with only a few stories. Controlling these lines could be done similar to grids in the section settings where it is a simple tick-box of which lines to display. this would be very helpful for quickly establishing existing & proposed ridge lines, floor set-downs etc.
Lingwisyer
Guru
+1 add a pole
Win10 | R5 2600 | 16GB | GTX1660
jl_lt
Ace
And it would be great being able to reference elements to those reference levels, like slabs or beams so you could move and adjust independete of the main slab level
