2004-01-11 12:28 PM
2004-01-11 02:29 PM
2004-01-11 07:22 PM
Matthew wrote:I just did it ... but have to add the Poll manually ...
IOOPS. I just went back and read the original request ("purge unused layer") and now understand the "Not needed" votes.
It seems that this wish should be reconstituted to reflect James suggestions since they are quite important.
What is the best way to do this Djordje?
2004-01-12 05:22 PM
jamesm wrote:Layer merge ! Can I vote 10 times for this one ?
2. Merge a layer into another. When you merge data from an old project, sometimes standards have changed and you end up with two layers of nearly the same name and exactly the same function, causing confusion going forward.
2004-01-12 10:23 PM
Matthew wrote:Well said. This is a royal pain in the you-know-what. Merging would be a fantastic addition to A-man.
I have done MANY layer conversions. They are quite tedious and filled with potential for errors. Having to turn on one layer at a time, search through the entire project for all elements on that layer and move them to the new and/or correct layer, and then having to repeat the process for all the affected layers (ALL the layers in a standards conversion process) is a very unpleasant job.
2004-02-03 06:47 PM
2009-09-19 07:27 AM
2009-09-19 06:12 PM
another Moderator
2012-08-17 03:52 PM
2012-09-04 12:58 PM
