Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Removing layers procedures
Might we add to the Attribute Manager (then roll the whole thing into the layer dialog):
1. Send elements on deleted layers to the ArchiCAD layer, or prompt the user for a layer for this purpose.
2. Merge a layer into another. When you merge data from an old project, sometimes standards have changed and you end up with two layers of nearly the same name and exactly the same function, causing confusion going forward.
3. Stop reporting that a layer is in use when it is merely currently set in a tool default. Or differentiate these uses.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
13 REPLIES 13
We still need this. I just spend an hour manually moving elements from layers that I want to delete to other layers.
Please make a merge layers function--please.
Thank you
Eduardo Rolon
John this wish has already been granted since 17. When you delete a layer in AC it asks what to do with the elements that are in it: "Delete or Move to another Layer"
• or you are asking for something else?
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
ejrolon,
Reason enough to upgrade.
Thank you
Eduardo Rolon
Amongst other things.
AC27 US/INT -> AC08
another Moderator
