2007-11-12 01:35 AM
2007-11-12 03:31 AM
As it is now, you HAVE to model everything.I thought that is the point of VB or BIM.
2007-11-12 08:53 AM
2007-11-12 09:16 AM
Rob wrote:True. True.
2007-11-12 09:18 AM
Thomas wrote:Thomas, I have tried that method before and it doesn't always work. I think it depends on the seed file of the DWG whether it is 2D or 3D. I know though that sometimes it flat out doesn't work.
A simple workaround to see 2D floor plan elements in 3D is to export as DWG and then import the DWG as an object.
2007-11-13 10:00 PM
2007-11-13 11:48 PM
Dwight wrote:Thanks Dwight. That would help for small cases. Imagine having a site plan with thousands of lines that you want to show flat... Uuuuugh!
While in full support of having easy 2D to 3D line work, there is a cumbersome and ridiculous workaround.
I've made some objects that will appear in the 3D window as lines.
I"m embarrassed to offer these rudimentary elements, but some may find them a bridge until the real thing comes along.
Uploaded, for what they are worth, to the Object Depository/01 General: "3D lines and circles.zip"
2007-11-14 12:01 AM
2007-11-14 12:07 AM
2007-11-14 12:23 AM
Link wrote:Hmmm, can't access your texture link... Will try later. But, I assume maybe it's the same thing as I mentioned above by applying it as a hatch to a material to show in the 3D window.
Bit longwinded for your case, but you could apply it as a texture.
Link.
