2019-03-12 10:12 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-05-24 08:14 PM
2021-05-25 04:13 AM
Podolsky wrote:
you can easy change the shape, as it would be the fill.
2021-05-25 04:16 AM
2021-05-26 03:26 AM
Podolsky wrote:... and a drawing placed on a Layout cannot be modified without opening the View that it is linked to, which in the case is equivalent to opening the DWG file, of which the ignored xclip originates from...
Actually the same way how drawing, that placed on Layout.
2021-06-29 05:35 AM
2022-04-20 08:47 AM
Fun times...
2022-04-20 08:59 AM
@Lingwisyer Any possibility you can bring the dwg in as a drawing and clean up the view by modifying the source layer settings? I have had drawings like this, if it is just for use as a trace simply turn off everything and rebuild with the required layers. Assuming the source has followed some kind of layer discipline... 🙄
In one case (dwg from Vectorworks) it was easier just to work from a well dimensioned pdf.
And as a last resort an exploded pdf.
2022-04-20 10:02 AM
I actually did not think of working from a vector PDF. It is snaps properly, that would actually work perfectly.
